Creating a Parametric Drawing of Stacked Symmetrical Rectangles
I am working on a parametric model for clearances of rail cars.
We get dimensions from the field for cars that are considered dimensional. We get set of basic outline dimensions of widths at various heights.
The sections of the load are always symmetrical and the heights are from top of rail.
Is there a way to create a set of stacked rectangles that are constrained to be symmetrical about a centerline with horizontal lines all touching? The goal is to ensure that the car outline has enough clearance to pass through the constraints of the railway corridor.
I've attached a sample drawing to illustrate.
Thanks.
Steve_Bessette
Autodesk Support
Autodesk Support
From your description, I believe that the use of a Dynamic Block may be the best solution to your workflow. Dynamic Blocks contain rules / parameters that will allow the block reference to have different appearances depending on the design requirements. The links below will provide additional information.
About Dynamic Blocks
About Creating Dynamic Blocks
About Adding Actions to Dynamic Blocks
About Adding Constraints to Dynamic Blocks
About Controlling the Visibility of Objects in Dynamic Blocks
Please let me know if this helps. If it does resolve your inquiry, please click "Accept as Solution".
Best Regards,
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
I completely rethought the approach and went with a set of parametric vertical lines on one side of the centerline. Then, I joined the vertical lines using horizontal lines - constraining the lines to intersect. This created a parametric outline on one side of the centerline.
We can enter the dimensions in the parameters manager and it will generate an outline for the load.
In the end, it is fairly simple for the user and works well.
Thanks for your suggestions.
Cheers.
Brian.
