Copy paste resulting in bigger scale
Yashasvi23481
Yashasvi23481
Hi All,
   I am using 2018 AutoCAD Mechanical. When I copy the contents of 1 drawing onto other (both have same sheet size), the pasted item is much larger than sheet size. I checked the ratio, it was more than 25.4 (in case in was copied to mm unit).
   Well, I modified the content to what I wanted to do and made a block and zoomed to fit in sheet. When I tried to explode dimensions were all over the place. but when I did refclose to save, it went back to original. What could be the reason for this behaviour ? Both drawings (copied from and pasted into) have units listed as unitless. See the 2 jpegs attached. I have tried copybase too. source and destination have same size for text how is sheet size differing ? i have to make lot of changes to each sheet n there are 19 off them.  cant keep repeating same mods on each of them. You can see in resultant drawing jpeg that title block is lying so small compared to bottom of the content in red  border. whereas AutoCAD error.jpeg shows dimension blown out when block is being modified.
When I make a block why does dimension explode as shown ? If I could control that, I can copy block and explode and re block.  Do I scale drawing without creating block ? In doing so, will dimension be scaled too ? I know I can solve this using viewports but we rarely use layouts, all work is done in model space including title block.
Please help.
Thanks and Regards,
Yash
Yashasvi23481
Hi All,
    I figured out what was the issue, the scale of title block itself. The one I copied drawing from has scale of 100,100,100 for X, Y and Z whereas the one I was pasting into was 1,1,1 so I compared item by item and worked out. once I modified the scale of pasted title block, I didn't need to create block and scale.  I had to rescale the content of title block and other. Will mark it complete to signal issue is resolved.
Yash
