conversion from STEP to DWG
Message 1 of 8
Is it possible to import STEP models into AutoCAD Mechanical 2018 to convert them to DWG format?
Replies (7)
Message 2 of 8
lakshmankumar.satya
  Yes it is possible to Import step files to cad.
  Use Command: Import
  Change files of type to Step
  Browse your step file and click open.
Message 3 of 8
I have the 2018 version and when I select Import, it does not open a box for me to navigate to my desktop to open the STEP file like it did for the earlier versions. That why I think it is not possible for this the 2018 version. I think I might need some other type of software for this. Would that be possible?
Message 4 of 8
Sridhar-Autodesk
Can you type the command STEPIN and verify if this helps?
Select " File of type" as Stp or Step.
Sridhar Subramani
Senior Product Owner
Message 5 of 8
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
That sounds frustrating! It is possible one of your system variables got changed. Try typing FILEDIA, and change the value to 1. This variable determines whether dialog boxes are shown (1) or if the information is shown in the command line (0).
If my post was helpful, Kudos are always welcome.
And if it resolved your problem, please select the Accept as Solution button.
Hope that helps,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 6 of 8
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if you still need help with this or if you were able to resolve the issue.
All the best,
Cheryl Buck
Message 7 of 8
gaurav.satalkar
Import will not show you the STP or STEP file extensions for importing the files.
The only way to import a Step file in AutoCAD Mechanical 2018 is to use the command STEPIN. You can use the STEPOUT command to convert the dwg into a .stp or .step file format.
Hope this helps.
Thank You,
Gaurav Satalkar
QA Engineer
Message 8 of 8
Rob67ert
Hi, do you use multiple monitors? It could be that the window is "off" screen. If that is the case, select import and then use "alt" and "space" and then "m" for move. With the arrow keys your can then try to get the window back on your screen.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
