AutoCAD User interface
Hi autoCAD people.
Why do you always move around command menus and change user interface? I am starting to lose control of autoCAD in the recent versions. Everything used to be simple and organized. I have just looked at the 2016 version and everything is a mess to me. Why do you make it more difficult fo rnew people to learn your product. this just doesnt make sense.
pendean
Community Legend
Community Legend
It's called progress 🙂
Sridhar-Autodesk
Hi
Apologies for the inconvenience caused.
You may migrate your previous settings using 2 ways;
1. If you have both previous version and current version installed on the same machine, you may use "Migrate from previous Release" option from Windows Start programs>>Autodesk>>AutoCAD Mechanical 2016>>Migrate custom settings>>"Migrate from previous release"
OR
2. If the previous version is on a different computer, you may copy the CUI file from the support folder.  Load this CUIx file in the current version using CUILOAD command.
Please let us know if you need more detailed steps.
Sridhar Subramani
Senior Product Owner
