Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AutoCAD Mechanical IS NOT PUTTING DIMENSIONS ON THE CURRENT DIMENSION STYLE
3 REPLIES 3
cadking2k5
605 Views, 3 Replies
How do you get AutoCAD Mechanical to put the dimension on the current dimension style
3 REPLIES 3
pendean
in reply to: cadking2k5
Do you mean your dimensions are using a different dimstyle that looks nothing like you want? From HELP https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/201...
Or do you have have a dimstyle override that is adding a little extra that you wish to get rid of? From HELP https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/201...
do you make it? i have the same problem
I have had the same problem but found out that for some reason autocad was creating a override dimension style for my current dimension style. When it happened occasionally I had to check in DDIM the dimension style and SET CURRENT  to my dim style. I think it usually did the override dimension when I was dimensioning through a viewport.
