AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Autocad mechanical dimensioning, when using tolerance "Limits" with a line break, dimensions are not centered between arrow lines
1 REPLY 1
hal_chadwick
130 Views, 1 Reply
Morning I have  couple of things;
Also how can I permanently change the line break from "\X to \P"?
1 REPLY 1
To center dimensions with line breaks, adjust dimension style settings, text height, and spacing. Consider using a leader line for more control. To change the line break character, modify the text style or use the DIMSTYLE command.
