Announcements
autocad mecanical B.O.M setting question~
hellow,
i have some question of B.O.M setting status. there setting interface have some  character.
precision is 0(zero) to character of QTY
I'm make some  B.O.M material qty is count of 0.123 for example.
so how to make precision to 0.XXX? is Not make new character. only base setting character of QTY
thank you for your kindly reply
Sridhar-Autodesk
Hi
QTY BOM property is hardcoded.  You can workaround using following steps
1. Command: BOM>>Settings
2. Create a new Property QTY. as shown in the below image.
3. Remove the old QTY property
4. using the newly created property, you will be able to add required precision.
Sridhar Subramani
Senior Product Owner
Thank you for your kindly reply to quikly
I make new QTY. that saw partlist decimal point ok.
but lead zero <-- insert 000.x setting.
example insert 22. partlist saw 022. i'm clear saw 22.xx
QTY 0~100 or 1000 step. it's means of insert 33 . part list saw me 0033.
i want saw only 33 not include 00<--.
thank you.
Sridhar-Autodesk
Hi
In the BOM settings dialog, please change the LEAD ZERO to 0.0 and verify the issue.  OR can you send me a sample drawing to take a look.  Also let me know the version of AutoCAD Mechanical.
Sridhar Subramani
