AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Autocad changing dimstyle itself
2 REPLIES 2
rob_deans
131 Views, 2 Replies
Hi all, I am experiencing a problem where Autocad is changing my current dimension style to AM_ISO on its own, and I can't work out what I am doing that is triggering this action.
I have set the style EDP 1.5MM seen below as current in my template, but when I create a new drawing AM_ISO is set as current. I then manually set EDP 1.5MM as current and a few minutes later ACADM has reverted back to AM_ISO as current.
I'm having a hard time deleting the style, it's nested in a few other things and I figure its harmless as long as I can solve this issue i describe.
Any ideas?
2 REPLIES 2
pendean
in reply to: rob_deans
Dumb question, but did you go here to change your default? And checked that box too
https://help.autodesk.com/view/AMECH_PP/2023/ENU/?guid=GUID-EFEC462E-5433-4153-BE59-A304BE962ADD#:~:...
rob_deans
in reply to: pendean
If that was a dumb question what does it say about me that I hadn't done that? I was changing the settings in the actual drawing.
Thanks @pendean , looks like it is no longer switching styles.
