AutoCAD Balloon leader arrow size
Hi, I am using the standard AutoCAD BOM method for my cross section drawings. I want to change the size of the arrow head for the balloons. I can find an option to only scale the entire balloon, but what I need is to keep the text and balloon size intact and change the arrow head size oly.
Its will be greatly appreciated if you guys could please provide your suggestions in this regard. Thank you
If I get what you're saying, this should be worth a shot:
Go to oprions. Under the AM:Standards, double click on ANSI. THis will open up your standard settings for ANSI. You can adjust your standard ANSI arrowhead size here.
Now, go back to your AM:Standards tab and double click on balloon.
When your BOM Settings for ANSI pops up, select the balloon tab and click on the button in the Default Style box. This will open up another pop up for your balloon settings. Make sure your arrow heads are set to "By ANSI" and hit OK.
This works for me, so I hope it'll work for you too.
I forgot to add the second attachment
@Shiploose, thank you for your valuable feedback. The solution is working as I needed it to. Thanks once again Smiley Happy
