AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Associative radial and diametric dimensions do not update in nested block
0 REPLIES 0
Message 1 of 1
rohit_rajivade
149 Views, 0 Replies
Hi, while working with dynamic blocks I've observed one issue that the dimensions associated to a block nested inside another block (specifically radial and diametric dimensions) are not updating when its (nested block's) dynamic parameters are changed as shown in below images.
Below image shows that dimension is associated to the block
Below image shows initial parameter value (SS_OD)
Below image shows updated value (SS_OD)
Even after changing parameter value the dimension has not changed
Below image shows that the dimension is still associated
If anyone faced same issue and has solution for this, please let me know. Any leads are appreciated. Thanks in advance!!
0 REPLIES 0
