I've got a bunch of one & two stroke commands that I locate on the left side of my keyboard, to improve drawing time. I use: 1, 11, 2, 22, Q, A, S, AA, SS, and so on....
The issue is the when I enter Aliasedit, it takes me to the AutoCAD Alias Editor window that I am accustomed to, Attempting to ADD a new command: I enter (for example: 1 for Dimlinear), now i click the OK box. Then both the New Command Alias window & the AutoCAD Alias Editor window close at the same time.
It never gets me back to the AutoCAD Alias Editor window, where I have to save my changes.
(using Autocad Mechanical 2020)
Any clues?
I can't see the issue. I could add a new alias:
This ALIASEDIT is in a separate process so you may miss it in Windows task bar:
Regards
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
I am also not seeing the issue you described. A couple things I can think of that may be causing the issue are the updates for AutoCAD Mechanical and core AutoCAD are not installed (both need to be installed for some features to function properly), or the user profile is damaged.
To install the updates, see Update software in Autodesk Account | Download & Install
For a damaged user profile, see How to reset AutoCAD to defaults.
As a workaround, other methods are available to edit the aliases, my preference is through the PGP file. This can be done from the Manage tab in the ribbon. In the Customization panel select Edit Aliases, then Edit Aliases from the drop down.
This will open the PGP file that stores all command aliases. There is a section a the bottom of the file called User Defined Command Aliases that is designed to override any of the native command aliases. In AutoCAD Mechanical, this section includes all the AM specific keyboard shortcuts.
I like using this method since it is in a basic text format, can be saved out and edited in a text editor, then copied back into the file. Just follow the format as used with native commands. Here's what a portion of mine looks like:
See To Edit the Program Parameters for more options.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
I installed autocad on a new laptop, problem is NOT present on this laptop.
I'll have to check my other install to see if issue still exists there....
Hi @Anonymous,
Thank you for the update, I am glad you are not seeing the issue on the new computer. If you are still seeing it on the previous one, it may be a corrupted user profile.
You can test this by resetting to defaults, see the Autodesk Knowledge Network (AKN) article How to reset AutoCAD to defaults. You will get the opportunity to export a copy of your current settings prior to the reset. If this resolves the issue, you can test to see if the issue returns if you reimport your settings.
All the best,
Is it as simple as what I've been dealing with for years:
Open up the Command Alias Editor (CAE)
Make my edits
Click OK
Everything disappears
Minimize the C3D (or Map 3D for me) window and there lies the CAE window meekly hiding in the background waiting for me to select OK for the second time (which is standard procedure).
I've found that the CAE dialogue box just hides behind the cad program you're running.
