Subject: MAP New features - 03 - KML/KMZ GIS interoperability
Hello
So after my very long wish list :
http://forums.autodesk.com/t5/autocad-map-3d-general/map-3d-2016-quot-new-features-quot/td-p/5573909
and especially my message : 04-10-2015 10:51 PM in reply to: gluckett
And don't forget the answering message of albert : kalman.albert - 04-11-2015 03:44 AM in reply to: braudpat
I will propose new features for ACAD MAP in each category !
****** Must have : KML/KMZ GIS interoperability ******
1A) Please a NEW KML/KMZ FDO driver ! - (with attributes/object datas)
or if not possible
1A1) KML/KMZ format with MAPIMPORT/MAPEXPORT (with attributes/object datas)
2) Please in the past (ACAD 2008-2012), we had a KML/KMZ plugin (Labs) to generate 2D/3D KML/KMZ graphic !
Why you can't recompile it for MAP 2015/2016/2017 ???
I am always using it with my good old MAP 2012 or MAP 2011 ...
Regards, Patrice (I am not an Autodesk Advisor)
4 Comments
georges.kacou
I think that it would also be good to add support for GeoJSON (and TopoJSON) files through a new FDO driver. This would also benefit AIMS since those JSON formats are gaining adoption in the webgis arena.
Gary_Braun
I think this is an excellent suggestion George. In order to raise its profile somewhat, you should add this as a separate post rather than tagged on as a comment.
-gb
km11
It is a great idea! What is the complete workflow when you import KML data?
Do you want to import it, edit, stylize and then export back to KML?
 Kavita
kalman_albert
We finished a plug-in for Map3D that solve export to KML requirement. The application is very powerful and can export AutoCAD objects and any kind of FDO, powerful styling, zoom level, labe from block attributes or values from FDO fields, combine coordinate system, spatial filter.
For kml Description is possible to set complex structure, like dynamic generated html page from a service (for example: REST services), or simple html page.
Also there are  some short video about this application on our channel : https://www.youtube.com/channel/UCmSxcGiC-ulzuMutshxeBqQ
If somebody are interested there are a full 30 days trial version, can be downloaded from http://cad-gis-mures.ro/index.php/en/pmxexportkml-en.
What you see in Map you can have in Google  Earth!
 Albert
