Hi all
I
want to show a specific length (for example: 1350 meter) from specify point on the network of main and secondary pipe lines.
Of course, I raised this problem in the map 3d forum so that maybe it can be solved by creating a topology.
But it seems that this is not possible in map 3d (network topology analysis: Shortest Path,Flood Trace,Best Route).
The point specified by the user can be at the beginning of one pipe(polyline) and at the end of another pipe(polyline) at the same time .
But surely the point selected by the user will not be somewhere else on the polyline.
I want to specify the start point ,then program to select the polylines that are in contact with it and to show a point on the main pipes and branches.
and all the main pipes' Polylines and all sub pipes' polylines no contain arc segments.
IDEA Network Topology.dwg
