We use AutoCad Civil 3D 2016 (Basically Map 3D) for all of our GIS building with layers. I have one sdf layer in a drawing that shows up in the display manager. When I right click on the layer name and then click on <Show Data Table>, the Data Table populates with all of the pertinent data in each column. Within the Data Table, I can temporarily slide and relocate each column into a different position. Isn't there a way to permanently move columns in the Data Table that will stay where I move them? If not, there should be. With today technology, I can't believe we are unable to make this happen. If I have to edit information say for a parcel, it takes me several minutes each time to re-order the columns so that they are in the correct order to edit the data. Very inconvinient, especially when I am dealing with data tables that have sometimes as many as 40 or 45 different columns of data like our zoning layer.
Autodesk has informed me that this is not possible. "Interesting".
