When creating a new feature from geometry in the FDO layer, it would be extremely helpful to automatically map the AutoCAD properties to matching column in FDO.
For example:
Block attribute install_date matches SDF column called install_date.
Or
Object Data called owner matches SHP column called owner.
The right-click "Create new feature from geometry" would auto-match the block attributes or object data to the column of the same name.
