Access to OGC WMTS-based data store
OSGeo FDO Provider for WMTS !
23 Comments
Indeed!
National Data and maps are provided in WMTS: http://www.ngi.be/cartoweb/1.0.0/WMTSCapabilities.xml
We still cannot access the data and less data is provided in other services than WMTS...:-(
mpe
A WMTS provider is one of the most needed improvements for AutoCAD Map 3D. I was hoping version 2017 would help us out, but unfortunately it didn't. AUTODESK please help us !!!!
John_DeLeeuw
Hopefully the coming 2018 version will do...?
Also, make this available in ALL Autodesk software like AutoCAD Civil 3D and Autodesk InfraWorks 360! WMTS offers far more performance then WMS.
Greetz to @Anonymous and @mpe 😉
ahuygen
WMTS for the autodesk products would be very usefull
please implement this
e.fromont
Agreed, please implement WMTS, it saves from having to download aerial imagery in a dwg format and referncing it into an existing CAD drawing. Saves time, and a heap of space aswell.
shefqetlulja
Yes, this is a MUST in the mapping technology, the need of this feature makes me use other GIS apps.
brad.nz
2 years on and still no WMTS... :`(
shefqetlulja
I don't know why thi MUST feature for mapping is still missing in autocad map. This is pushing me using other software.
marek
I found a very good solution. It took me only half day to install, configure and test. Now I have WTMS sources connected to Autodesk software via WMS connector connected to my MapProxy instance. My MapProxy instance caches tiles, so it should be faster. 🙂 Link: https://mapproxy.org/
shefqetlulja
Can you tell your feedback about the speed cause autodesk is really slow on this feature.
brad.nz
Another year down Smiley Sad
gliebig
Agreed! Our county only turns on the WTMS on their orthos. It's stopped me cold as the county provided maps are much better than the enhanced BING maps. I don't want to see the leaves on the trees!
Would be real nice if this wish did not reach a 5 yr anniversary. Seems like 4 is a go.
gmeinero
still waiting for wtms in autocad....
Please Autodesk, we are shortly going into the next decade. Give us WMTS!
juliewang
Thank you all for speaking out the request. I am happy to let you know that the WMTS access capability is enabled in Map 3D Rogue beta and you are welcome to try it out by joining the beta program at https://feedback.autodesk.com/key/Map3DBeta and look forward to your feedback.
John_DeLeeuw
Hi @juliewang , will this mean that also InfraWorks and Civil 3D can start using the WMTS FDO provider in the 2021 releases?
juliewang
Hi John @John_DeLeeuw, good question and also difficult question for me to answer at this moment. As you may know that by legal obligation, I am not allowed to comment on 2021 release yet. Conclusions could be only drawn on your own.
John_DeLeeuw
Hi @juliewang , I'll ask the same question on the feedback forum, you will be able to answer there.
JackFanZhang
Observer
An InfraWorks user from year 2021 here just to check the progress, no pressure.
