XREF Transparency
XREF Transparency
Message 1 of 22
XREF Transparency
Just upgraded from AutoCAD Map 3D 2009 to AutoCAD Map 3D 2011, and noticed that by default my XREFs are showing up with what looks like a 50% transparency giving them a "washed out" look.
Is there a system variable to correct this?
Replies (21)
Message 21 of 22
JReidhead
While trying to figure out how to post my drawings here so I could get your help I discovered the Bind command (so my xrefs would be connected to my drawing when I uploaded them) and It solved my problem 🙂  Turning an xref into a block may not usually be the best thing to do, especially if one may want to update it, but it works GREAT with an image that will not change.
Message 22 of 22
JReidhead
I think I actually figured it out now.  I tried many things in the dwg that I was xreffing into my working dwg, as well as the working dwg itself, but I hadn't tried the beautiful "fade control - xref display" SLIDER from within the xref dwg.  Worked like a charm.  Sorry for my less helpful posts prior to this one.
