Wrong georeferencing
nikola.boskovic2
Message 1 of 18
nikola.boskovic2
Hi, i live in Montenegro and we use EPSG code 8678. That code is equal to EPSG code 31276 but in autocad 3d map 2021 is not like that. A few days earlier when use code 8678 is great but after update that is not the same. Now with that code I get arial picture 1 mile to right side. What is the problem and how can solve this?
Replies (17)
Message 2 of 18
Pointdump
Hi Nikola,
I can't find EPSG:31276.
Are you using Bing Live Maps or do you have georeferenced images?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 18
nikola.boskovic2
I use BING map. That code is in "Not filter selected"
Message 4 of 18
Pointdump
Nikola,
Check the extents of EPSG:8678 in MAPCSLIBRARY. Occasionally they're not correct. You can change the extents >>>This Way<<<. Please post a screen shot of the map being off. Is it like this?
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 18
nikola.boskovic2
it's same
Message 6 of 18
Pointdump
Nikola,
That sure looks like a Datum shift, from MGI_1901 to WGS84:
>>>EPSG:8678<<< shows this:
TOWGS84[682,-203,480,0,0,0,0]],
(682 Meters East and 203 Meters South)
Can you post your shapefile? (Zip together DBF,PRJ,SHX,SHP)
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 18
nikola.boskovic2
I don't have shp file, this is dwg (geodetic file). I use map for better orientation.
Message 8 of 18
Pointdump
Nikola,
Can you post the drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 18
nikola.boskovic2
because file is to large I send a part of them
Message 10 of 18
Pointdump
Nikola,
Just now opening up your drawing. Thanks for posting it.
Your drawing is set to Imperial (Foot) Units.
EPSG:8678 is a Metric Coordinate System.
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 18
nikola.boskovic2
How can get that window for configuration in 3D MAP?
Message 12 of 18
Pointdump
Nikola,
Sorry, I forgot you don't have Civil 3D. In Map 3D and Vanilla AutoCAD use Command -DWGUNITS.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 18
Pointdump
Nikola,
I experimented with several different coordinate systems, and BOSNIA-6M-S9 came closest. 460 Meters off.
I guess you need to ask whoever you got this linework from what the coordinate system is.
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 18
nikola.boskovic2
I appreciate you trying but this didn't solve my problem. This work before windows update, I doubt that it is due to an update, but I don't know where to look for those settings
Message 15 of 18
Pointdump
Nikola,
I grabbed a road shapefile and dropped it into your drawing with EPSG:8678 assigned. Note they do not match. Where did you get your drawing?
Shapefile attached.
Dave
Dave Stoll
Las Vegas, Nevada
Message 16 of 18
nikola.boskovic2
the drawing is from the geodetic cadastre. All lines is 100% correct with dimensions and that work before win update. The booth EPSG code are approximately the same.
Message 17 of 18
Pointdump
Nikola,
Can you post the original geodetic cadastre drawing, or even better, a link to where you got it? If the drawing is over 71MB you can use WeTransfer or DropBox link.
I don't doubt that all lines are 100% correct, but they are not correctly located. I suspect a Datum difference, MGI_1901 to WGS84.
I don't know how a Windows update could cause this problem, but stranger things have happened, so maybe.
Dave
Dave Stoll
Las Vegas, Nevada
Message 18 of 18
nikola.boskovic2
I solved the problem by reinstalling the operating system. In any case, I thank you for your help and advice
