10:46 AM
When I use AutoCAD Map 2015 to connect with a WFS-service all works fine for layers with point and polygon geometry, but layers with lines always return zero rows. Also the structure of the attribute table is wrong: the geometry column is renamed to SHAPE-dot-LEN and attributes are missing. I don't get an error. An example of a WFS-service that I used for testing purposes is
http://geoservices.provinciegroningen.nl/ArcGIS/services/OpenData1/MapServer/WFSServer (layer RoutesFietsknooppuntennetwerkGroningen).
I've got WFS FDO connector version 3.9.0.6702.
Does anybody have similar problems with WFS or knows a solution?
Willy
