Water Industry Model Diameter Issue
I have connected shapefiles for pipes and junctions
i can export them fine but have to set the diameter manually from (Diameter inside, ouside and nominal) and after converting to civil 3d the pressure pipe is the same diameter and it's called (nominal diameter description) it varies while selecting (inside, outside and nominal in map 3D) but all pipes have the same diameter.
although the industry model has the diameter different values in civil 3D but after creating pressure network from industry model, i get the same diameter for all the model.
Please help
