AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
VB for CAD
5 REPLIES 5
315 Views, 5 Replies
VB for CAD
I was wondering if anyone used VB for Autocad, I have minimal VB training, but am trying to write a small program. I'm stuck on hgetting user imput, so if anyone knows what I'm doing wrong, it would be greatly appreciated if you let me know what it is. I know mt argument is bad, but I'm not sure what to do to fix it.
Here is the code:
Private Sub cmdCancel_Click()
Unload Me
End Sub
Private Sub cmdNext_Click()
frmROWOFFSET3.Show
End Sub
Private Sub cmdSelect_Click()
Dim ent As AcadEntity
Prompt = vbCrLf & "Specify line to offset: "
ent = ThisDrawing.Utility.GetEntity(getobj, basePnt, Prompt)
End Sub
5 REPLIES 5
Try something like this,
Dim MyLine As AcadEntity
Dim basePnt As Variant
ThisDrawing.Utility.GetEntity MyLine, basePnt, "Select an line"
That's VB"A" code that should work.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
wrote in message news:5683407@discussion.autodesk.com...
Here is the code:
Unload Me
End Sub
frmROWOFFSET3.Show
End Sub
End Sub
There are many people doing AutoCAD programming with VB/VBA. You may have
better chances to get anwsers to your future questions in
autodesk.autocad.customization.vba NG.
Here is comment on your code.
Since the UserForm in Acad is modal form (by default), meaning when form is
shown, you cannot reach Acad editor to allow user to pick something.
So, you code in cmdSelect_Clcik event handler should be like:
''Hide the UserForm to allow interactive action to Acad
Me.Hide
''Do the pick
'You need to add "Set" keyword
Set ent = ThisDrawing.Utility.GetEntity(getobj, basePnt, Prompt)
''Do something with the picked Entity
'When done, show the UserForm again
Me.Show
End Sub
Here is the code:
Unload Me
End Sub
frmROWOFFSET3.Show
End Sub
End Sub
Sorry, the middle line of code should have been:
ThisDrawing.Utility.getEntity ent, basePoint, Prompt
"Norman Yuan" wrote in message
news:5683489@discussion.autodesk.com...
Me.Hide
''Do the pick
Me.Show
End Sub
Here is the code:
Unload Me
End Sub
frmROWOFFSET3.Show
End Sub
End Sub
THanks, everyone for your help! Is there a way to get the entity selected to be forwarded to another form? What the idea is is that the user selects the entity, selects Next, then selects the amount of space to offset the object. (i.e. 33' either side, 50' either side, 12' either side) (This program is for setting up a Road Right of Way for a utilities map.
Here is the project so far, sorry I guess having the full project up would have helped a little more, its not finished yet, but still trying to figure out code for running the offsets, and changing the orginal selections layer.
Form 1
Unload Me
End Sub
Private Sub cmdContinue_Click()
frmROWOFFSET2.Show
End Sub
Private Sub TextBox1_Change()
End Sub
Private Sub Label1_Click()
End Sub
Form 2
Unload Me
End Sub
frmROWOFFSET3.Show
End Sub
Me.Hide
'Hide the UserForm to allow interactive action to ACAD
'do the pick
Dim BasePoint As Variant
ThisDrawing.Utility.GetEntity ent, BasePoint, Prompt
Me.Show
End Sub
Form 3
Private Sub cmdCancel3_Click()
Unload Me
End Sub
Private Sub cmdFinish_Click()
Unload Me
Unload frmROWOFFSET2
Unload frmROWOFFSET
End Sub
Private Sub opt100_Click()
End Sub
Private Sub opt24_Click()
End Sub
Private Sub opt66_Click()
End Sub
