TRANSFORM COORDINATES
sorinvictorgorski
sorinvictorgorski
how can I transform coordinates from EPSG:32635 WGS 84 / UTM zone 35N to EPSG:3844 Pulkovo 1942(58) / Stereo 70
Pointdump
Hi @sorinvictorgorski,
Depends on what you're transforming and what software you have. Do you have Civil 3D or just Map 3D? Are you transforming points, lines, or polygons?
Can you post a drawing with what you have?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
sorinvictorgorski
I have AutoCAD Map 3D 2024
I want to transform points coordinates from EPSG:32635 to EPSG:3844
Pointdump
1. MAPCSASSIGN UTM84-35N (EPSG:32635) to a new drawing.
2. Create Points:
Easting,Northing
281005,5077257
281525,5077959
3. Save and Close drawing.
4. MAPCSASSIGN Pulkovo42/58b.Stereo70 (EPSG:3844) to a new drawing.
5. On the Map Explorer Tab of the Task Pane, right-click Drawings and Attach your first drawing.
6. Under Query Library right-click Current Query and select Define.
7. Under Query Type select Location... >> All >> OK.
8. Under Query Mode select Draw, then Execute Query. You may have to use command DDPTYPE to make the points visible.
Bam! Done!
Dave
Dave Stoll
Las Vegas, Nevada
ChicagoLooper
You can do it with a QUERY. A query will transform from UTM84-36N (EPSG 32635) to Pulkove42/58b.Stereo70 (EPSG 3844)
1. SAVE your drawing with UTM84-35N (EPSG 32635). After saving, CLOSE the drawing. Next, Drag-and-Drop the SAVED drawing onto the Explorer Tab of the Map Task Pane.
Image-1Image-1
2. While still on the Explorer Tab, right-click Current Query=>Define.
Image-2Image-2
3. Make your Query settings like this then click EXECUTE QUERY.
Image-3Image-3
4. Highlight then right click your listed drawing on the Explorer Tab=>Detach.
Image-4Image-4
5. Turn on Bing Hybrid.
Image-5Image-5
Chicagolooper
