In my (German) MAP I have for "Fittings" the
- toolbar "tbcogo extractpoint" and
- in context menu "Aus Linie entnehmen / (Extract from Line(??)"
Is it the same?
Solved by urs_sommerhalder. Go to Solution.
Hi @Peter2_1 ,
It's not the same.
In the contex menu from Industry Model (Map extract feature geometry) is this function only by Utlity Model Objects available.
With this function, reassembled the soft splited geometrys and when the attributs are identical the hard splited as well.
The Cogo function remove the point and vertex from line, when they are within the toleranz (Settings in Global Map Options).
I hope its help so.
Kind regards
#Urs
