Style, style, style ... Autodesk puzzle
I offer a coffee for that who tell me how can I delete imported unwanted symbols (2) in the "repository". Where is this "Current repository" :Library\\" (1) ? Who knows? Nobody! No any information in the help about this.
Import button will import from a dwg all blocks but I want to select which block I want to insert, this option is not right designed and developed. After some analysis, I realize the most optimal will do have every symbol as dwg file. Personally, I'd like to have one file with project symbols, not "n" symbols files.
Load symbol as a copy - explained in help "This embeds the symbol within the style information of the layer. Any change you make to the symbol (for example, changing the insertion point) affects the symbol." is not very clear how.
I did discover that if I export the layer and then drag it into a new file, the repository is empty but the layer is symbolized with symbols, but where is the symbol? If it is needed to select it for another layer is needed to import it again.
Difference between 2013 and 2023 .. .10 years version almost nothing changed, the same option but now is gray.
The help is absolutely unusable and is very thin in information. maybe only those who develop this interface know, but I think they do not work daily with this interface.
10 years version help with K$ copy-paste but the dialog "Select a symbol in the repository" is not the same.
Where is the new version?
Autodesk friends, please make small efforts and write actual documentation with a little explanation because now is a big puzzle. The good news is, that we train our brains to guess how can we solve this.
There is an error "acmapdisplaymanagement.arx" ... this error 😵 drove me crazy, now I suspect they all have some relation with "symbols" that are saved in dwg in "library" and if something happened this becomes corrupt. No, any solution then to re-create the dwg. There is some functionality in as TBD (topoBase) interface with saved display, I do not understand why is not implemented in Map3D to use in any conditions.
2013 😅 . Yes, we still developing for 2013 custom application because there are customers with this version. As we see now there is no change between 2013 - 2023, no new features. And I can tell a lot, but I give up to be "a tester for nothing new".
Albert Kalman
"Nothing will ever be as it was!"
