Style Editor: problems with "<null>"?
Peter2_1
Peter2_1
Actually a simple thing..
The data-table has some values, like "Val A", "Val B" "Val C" ..
In Style Editor I have a definition like
VAL A = 1 or VAL B is 'red'
Should be clear, but sometimes I have "<null>" in Val A - and this "kills" the entire statement. Although "Val B is red", the statement returns false ...
Can you confirm this? Is it a correct behaviour?
I think "null is not 1, so go to the part behind the OR condition" .. Right or wrong?
AutoCAD Map 3D 2023 German / Oracle
parkr4st
change
to
VAL A = '1' or VAL B is 'red'
swt-gis
In my experience, the style editor interprets SQL differently than other programs.
To solve the problem we do the following (assumption: NULL may occur in field VAL_A):
Instead of
VAL_A = 1
We use:
VAL_A NULL or VAL_A = 1
It is important that the NULL part is at the front. This does not work:
VAL_A = 1 or VAL_A NULL
So your complete statement should be (to handle NULL in VAL_A):
(VAL_A NULL or VAL_A = 1) or VAL_B is 'red'
Regards
Jens
Peter2_1
@parkr4st
thanks, but I think that Jens's answer it the correct one.
@swt-gis
Jens, do you know if these details are documented somewhere in the official(!!) documentation?
So, as a result, the user has to modify 50% or more of his statement, because "null" can happen in a lot of fields ...
(I'm just thinking about it - if the "different behaviour of SQL statements in style editor and in datacheck and in ...." should be called a "Map SQL dialect" or simple a collection of bugs and strange implementations ...)
swt-gis
No, I don't know any documentary on the subject. What i've written is based only on my experiences.
Another problem that we solved by adding  NULL to the query:
Snapping to lines did not work:
NOT ID_DISPOSITION_STATE IN (10003,10004,10011,10012) and NOT ID_FUNCTION in ( 10006 , 10007)
That's how it works:
( NOT ID_DISPOSITION_STATE IN (10003,10004,10011,10012) OR ID_DISPOSITION_STATE NULL ) and ( NOT ID_FUNCTION in ( 10006 , 10007) OR ID_FUNCTION NULL)
Jens
