SKETCH command and touchscreens - different behaviors on different AutoCAD versions
JDLSites
JDLSites
Depending AutoCAD Map3D version, the SKETCH command, being used with a touchscreen, work more or less well.
AutoCAD 2022 and prior works fine : type the command and its parameters like "_SKETCH I 1" and draw something hand free with finger or stylus.
AutoCAD 2023 and later gives a degraded experience : with stylus or finger the first stroke is never detected, whereas with trackpad or mouse it works as intended.
Problem spotted on Surface Pro and a Panasonic CF-20 (rugged tablet).
Disclaimer : i know the general consensus is that AutoCAD is not a good fit for touchscreen, BUT :
  • we call this command in a house-developped plugin (tablet centric, used on construction site for reporting) and because of this degraded behavior we completely lose a feature.
  • this application has been developped and has been calling the SKETCH command for almost 20 years. The first release worked with AutoCAD 2007, it's been then ported to AutoCAD 2013, 2015, 2018, 2020 and 2022, always working.
  • I insist it is a change of behavior between AutoCAD 2022 (still working) and AutoCAD 2023 (not working anymore)
  • Sorry for this defensive statements, but I'm looking for a fix for something that broke, not advice for giving up on a convenience.
Note : I have a similar, probably related problem with .NET API for which I will make a post in the developers forums.
pendean
Community Legend
Community Legend
Everyone here is an end user just like you. And SKETCH command is not widely used enough, you might not get too many replies. In the meantime...
1) If you are on subscription... Here are the ways to open a support case with Autodesk to seek out Autodesk Support's help about the quirks you noticed:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
2) You are also most welcome to spend the next 1-2-5-10-20years regularly asking Autodesk to do something about it here at the website they look for feedback:
https://www.autodesk.com/company/contact-us/product-feedback
HTH
