I have the attached Lisp, which allows me to export out eTramital in AutoCAD.' At the minute, im having to open up each individual dwg and apply Lisp. I have a batch utility i can use, but for some reason, it wont work this way.
Am i missing something here?
Im hoping it a simple fix.
If not, is there a way of exporting multiple dwgs when using eTransmit?
Kev
I know enough of lisp to get myself in troubles...
Not too sure witch version of Map you are using but it is possible to add more files to your e-transmit
I think this may change in 2014 or 2015 if I am not mistaking...
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
