>> I'm really surprised that Map 3D doesn't have a way to change the Table Column Formats
Yes, with SHP-dataset it's really inflexible as it does not allowed to modify the structure of the attributive data at all, that makes the live with that quite hard.
A bit easier it's with SDF, but even that does not allow to modify existing attributes, it only allows you to add new coloumns. Sometimes it would be great to modify a datatype from string to integer if there are only numeric values existing ih that column, but no way, other tools are needed.
Well, looking more to databases for storing GIS-datasets (easiest case to SQLite) you also have to use the database tools to modify the structure and can't do that in Map 3D. That is one of the differences where other GIS-tools can do more than Map 3D.
>> Is DBF-Commander a Stand-Alone program or does it "attach" itself to Map 3D?
Yes, this is a stand-alone tool which has nothing to do with GIS or Map3D, in this case it's just used for editing DBF-file structure. And the free version can do that.
>> Here's the Official Pointdump Workaround:
Be careful, this will not work when the whole bandwidth of values is used (from 0 to 273000), but for the showed numbers all above 27200 I guess you have checked that and it will work 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
