AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
selecting items with an empty property
2 REPLIES 2
Michiel.Valcke
717 Views, 2 Replies
I have a schematic drawing of a grid network with names containing hyperlinks to other .dwg files (as-built plans)
I would like to see which texts still don't have any hyperlink attached to them. Is there any way to select all these items in one go with quick select or find.
In QSE if I choose "text" - "hyperlink" - "=equals" and don't put anything in the value box, it will not allow me to proceed with the selection. (the OK button is grayed out)
also using wildcard match to look for all the text items WITH a hyperlink gave erratic results.
I'm using AutoCAD Map 3D 2015 for windows.
2 REPLIES 2
first press <CTRL><A> to get all objects selected, then start _QSELECT with
  • apply to current selection
  • object type ...multiple
  • properties: hyperlink
  • operator: * Wildcard Match
  • Value: http://*
  • how to apply: exclude from new selection set
From all the selected objects the ones having a hyperlink starting with "http://" will be excluded ... that is your result I guess.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Since the OP's talking about path to .DWG, not WWW links, here's another way:
  • create a new layer, set it as current, set it off
  • _QSELECT as follows:
  • after clicking OK, run the _LAYCUR command
What displayed... yields the not-hyperlinked objects.
