Select some points
Select some points
allelopath
Message 1 of 12
Select some points
allelopath
I want to remove the part of the corrugated pipe below the red line (see image)
I can select each point individually but there must be a better way.
I tried Quick Select with Y vertex below -55.5455 but that didn't select anything.
What can you suggest?
dwg attached
Replies (11)
Message 2 of 12
ChicagoLooper
@allelopath
<<...I can select each point individually but there must be a better way...>>
I don't understand. What points are you selecting? There are no points, above or below, the red line in your drawing.
Even if there was a better way, could this better way select those points?
Chicagolooper
Message 3 of 12
allelopath
If you click on any part of the squiggly line, it selects all the points. (Attached another image to question)
Message 4 of 12
parkr4st
TRIM
select red line
then the Squiggly line "below" the red line to leave the portion "above" the red line?
or select "above" the red line to leave portion "below" the red line
keeping in mind below implies working along the z axis, not the y axis
Message 5 of 12
allelopath
This is a 2d drawing. I don't understand then how the z axis is involved
Message 6 of 12
ChicagoLooper
@allelopath
Your uploaded drawing contains e-x-a-c-t-l-y 5 objects.
They  are:
hatch 2 each
circle 1 each
polyline 2 each
TOTAL 5 objects.
There are no 'points' in the drawing you uploaded.
If there are points in your drawing, please select them.....and while they're still selected, upload a SCREENSHOT of both the selected points and the Properties palette.
Chicagolooper
Message 7 of 12
ChicagoLooper
<<...If you click on any part of the squiggly line, it selects all the points....>>
If I select the squiggly line the Properties Palette displays Polyline, not points.
If you are referring to the blue grips, you're mistaken. Those blue grip are not points, they are vertices and midpoints of the ARCS in the squiggly line.
Just incase you didn't know, the squiggly line can be trimmed using TRIM command. Treat the squiggly LINE like a line, not like a bunch of Points.
Chicagolooper
Message 8 of 12
allelopath
I mistook the grips for points. Can you outline the steps to use the TRIM command to trim the polyline, please?
I'm trying and can only trim the yellow object.
Message 9 of 12
ChicagoLooper
Do this:
  1. Start TRIM command. Go to Home Tab=>Modify Panel=>Trim (looks like scissors)=>Click your RED line=>Enter
  2. Using your cursor (cursor will now be square) click the portion of the squiggly line you want to go bye-bye=>click Enter to exit Trim cmd.
Chicagolooper
Message 10 of 12
O_Eckmann
Set TRIMEXTENDMODE variable to 0 to work with Standard mode which is more useful, than Quick mode.
Olivier
Olivier Eckmann
Message 11 of 12
parkr4st
as for the  reference to Z axis.  in real life the x y plane at world ucs is horizontal.  below that plane is -z, above the plain +z, thus i call those down and up.  matter of personal reference probably.
as an alternative you could break the pline at any two points and have two open plines.
Message 12 of 12
allelopath
I understand what you are saying about x/y/z. Though it is a matter of personal preference, I think Autocad may have its own preference. For example, if I right-click on a point and select Quick Select, in the Properties list box it has "Origin X" and "Origin Y". So it has something in mind. Whether Y is Y or Y is Z, I'm not sure.
Anyway, thanks for the suggestion to break the polyline. I used the BREAK command to do this. There are numerous ways to accomplish the task at hand (as suggested in other comments) but in this case, I found this to be the best.
