Announcements
Restoring deleted Map Features
lane.hargroder
lane.hargroder
I am just starting to explore the possibilities of Map 3D, so I am hoping there is a very simple answer here. If I connect to a shapefile and then select and delete a Map Feature associated with that connection, how do I restore it if I didn't mean to delete it? It shows as a greyed-out line in the Data Table. I would expect there to be a simple right-click option to bring it back, but I have yet to find it. Any help appreciated!
parkr4st
immediately key in undo ( CTRL Z ) and MAPCHECKINALL.   the feature will be restored.
Otherwise you may have to redraw the feature and enter the data.
Or query it back from the backup file
ChicagoLooper
Hello @lane.hargroder
That looks like parcel data. You may have downloaded the data but it was created by someone else. Correct? Since it’s periodically updated by the data’s managing party, your data is only as current as the date you downloaded it.
Even though you may have deleted a record (a ROW in the data table) the original data from where you downloaded is still intact. Disconnect from your locally saved data, re-download a brand new copy, then re-connect. You’ll be fine when you reconnect to the new data.
Chicagolooper
lane.hargroder
@ChicagoLooper @parkr4st
I was not fully grasping checking features in and out. I realize now that the line is grey in the data table to indicate it is a pending edit that has not been checked in/saved. IMO, there should be an option to keep or discard each pending edit from within the data table, but I don't see one. In my case, though, I don't want to edit the source data at all, so MAPCANCELCHECKOUT does the trick. Both of your answers helped me make sense of it all, so thanks!
ChicagoLooper
Hi @lane.hargroder
A ‘loose’ analogy to the check out and check in procedure is The Block Editor.
When you select a block from your current drawing, you can take it to the block editor for
editing. You may then exit the editor when you’re through making changes (or exit without making any changes at all).
In M3D, when modifying Feature Data Objects, check out is analogous to going into the block editor and check in is analogous to exiting.
Chicagolooper
parkr4st
checkin and out are things not to be over thought.  Merely the commands mean save the edits and enter edit mode.  Another software firm beat them to the terms and probably copyrighted the terms for that use so autocad came up with check in and out.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
