Removing AutoCAD via Regedit
Actually I tried to uninstall Autodesk AutoCAD Map 2016 via RegEdit of WINDOWS 10 64 bit, since uninstalling from Control Panel did not work for this software, that I do not know why. What I did was Finding (Ctrl+F) 'Autodesk' (without quote) and deleted them in RegEdit. But I could not delete all of them, since there are very very much 'Autodesk's there. After that I deleted all FILEs which have 'Autodesk' in their names in drive C.
Now I am trying to install the software again and can not. In installing window of the software it shows the software as an installed program, whereas I can not see it at Start or Control Panel as an installed program.
What can I do to remove it completely to install it again.
Experts of Autodesk please answer me and help me to uninstall it via RegEdit.
thanks a million in advance.
Thomas_Stuehle
Hi @Anonymous
Please use MS Fixit for your uninstallation:
You will find an article from the Autodesk Knowledge Netowork here: https://knowledge.autodesk.com/customer-service/download-install/remove-products/using-microsoft-fix...
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
thomas
It done. thank you a million.
Really really thank you.
