Removing a Coordinate System
cedwards8511
cedwards8511
Does anyone know how to remove a coordinate system from a drawing? I have a drawing that wasn't created with coordinates but somehow got one assigned to it. When I try to remove it, I have to assign something to drawing. You can't just leave the code area blank or it just remembers what was there before. Help...
This seems to work.
(setq cscode "")
(ade_projsetwscode cscode)
Copy those two lines to the command line with the parentheses if you don't
know lisp.
Murph
wrote in message news:5106996@discussion.autodesk.com...
before. Help...
cedwards8511
Thank you...that seems to do the trick.
FYI: you can use a period (.) to un-assign a system to a DWG.
Scott
