Regenerating error
Regenerating error
Message 1 of 9
Regenerating error
I am working with Autodesk map 3D 2006.  My map was working fine until this morning when I tried to open it. It will open up to 84% and then it gets stuck.  I managed to open it by pressing the escape key before it the regenerating command has a chance to act.  How can I correct this file to work normally?  I would greatly appreciate any help on this matter.
Replies (8)
Message 2 of 9
Alfred.NESWADBA
try to open the file using command _RECOVER, if there are XRef's inserted, then use command _RECOVERALL (hope that already existed in 2006).
If that does not work then you can create a new drawing, use command _ADEDRAWINGS to attach the defect one, and as the next step start command _ADEQUERY to get the objects from the defect drawing to your current/new drawing.
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
Thank you!  I will try that.
Message 4 of 9
I was not able to use any of the suggestions above because it still gets stuck.
Would anyone be willing to take a look at the file?  I would really, really, appreciate it.
Message 5 of 9
Murph_Map
Post it here and we will look at it.
A few other things to try is clean out your users temp files and any caches that you have on the workstation. Try to copy the file to a new folder with a shorter path on your local hard drive.
Also try to attach (ADEDRAWINGS) to a new blank dwg and query in the problem dwg.
Murph
Supporting the troops daily.
Message 6 of 9
Thank you, Murph.  I fixed it! I do have another corrupted file with a eNullObjectId error that limits exporting or querying of objects. Would you mind taking a look at that one?
Message 7 of 9
To Murphy,
I hate to bother you again but would you be willing to help me with another file?  I would really, really, appreciate it.
Message 8 of 9
Murph_Map
@Anonymous wrote:
To Murphy,
 Post the file here and someone may help, I'm not the only guru that helps out other users, there a hand full of us.
Murph
Message 9 of 9
Is there a way I could send this file privately to one of the gurus? It is an Oil and Gas lease map and my client would not be happy if I were to post it publicly. Please, let me know if that is possible.  Thanks a million!
