Re: Autocad 2015 crashes when trying to open Options dialog box.
I seem to be having the same problem, every time I try to open the options dialog box, AutoCAD Map 3D crashes!
None of the above solutions seem to work for me. Does anyone have any other fixes?
Alfred.NESWADBA
Seems your post has been moved ...
So now, in this thread, we don't see the "others" which problem they had and which suggestions were there. Can you please describe the issues and your trials to repair your Map3D?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Koesti
Autodesk Support
Autodesk Support
i @Anonymous,
as Alfred mentioned we need some more details - if it is possible to show a screenshot of the error message.
Or if it possible to send error report with your email adress to Autodesk we can check if there is something helpful.
Without the details one suggestion is to reset the profile of AutoCAD Map 3D
Another issue I saw with opening Options is there is an issue related to Online Settings and Proxy.
If you are loged in - logout from A360.
Try to open Options and disable the automatic sync options if enabled.
Kind regards
Brigitte
Brigitte Koesterke
Technical Support Senior Specialist
