Raster Image Color Issue
todd_beavan
todd_beavan
I am having issues with image quality when inserting NAIP  imagery into AutoCAD Map.  The issue happens when I insert the image into a drawing that's assigned a coordinate system other than the system from the image.  My drawing is in KY83SF, and the images are KY83F.  If i insert the images into a drawing that is in KY83F, then there is no color issues.  The images look OK in model space, but it looks like a color band is missing from the image...
When I insert the image into my GIS program (Global Mapper), I receive a message that the TIFF file contains a 4th band.  When I tell it that the band is an extra band of imagery data it looks good.  Thus my conclusion that it's a color band issue in AutoCAD.  I also have the same color issue when using the AutoCAD Map data connection to attach the image.
Any help is appreciated.  I included a couple of file outputs from AutoCAD to illustrate the issue.  The pdf is plotted from AutoCAD showing 2 different images side by side.  The word file is a screen shot of model space showing the differences.
Replies (9)
fieldguy
Try creating a new image from Global Mapper - IIRC export has a method to remove the 4th band
АлексЮстасу
What tool do you insert images?
If MAPIINSERT, then try disabling the Modify correlation option.
You can save the image in Global Mapper in a different format and immediately in the desired coordinate system.
In addition, you can adjust the display of the raster in the Properties window:
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
todd_beavan
You are correct, I could use Global Mapper to create the image in my desired coordinate system.  I'm hoping there's a simpler solution for AutoCAD Map.  It isn't a huge deal, but I'd rather not have to use a 2nd software to get my desired result.
todd_beavan
I am inserting the image using the MAPIINSERT command.  I don't want to disable correlation, because I want the image in my coordinate system.  I've tried to adjust the imagery display options, but nothing fixes the problem.
I've also tried to attach the image using the Map Task Pane, but unfortunately have the same result.
АлексЮстасу
MAPIINSERT image in a new dwg with the installed image coordinate system. Close dwg.
Attach in Map Task Pane this dwg with the image to the desired dwg.
Create a dwg content query with the image. Execute Query, Draw.
Detach dwg with image.
todd_beavan
I've tried that, but get the same result. Is it possible I have a system variable setting or something else set that causes the issue? Here is a screenshot of the 2 drawings side by side. The one on the left is of the image after I queried into my new drawing. The one on the right is the image inserted into a blank drawing on the same coordinate system as the image.
[cid:image001.png@01D568A9.A87E0310]
todd_beavan
АлексЮстасу
GM has a Batch Convert / Reproject ...
I have not heard about such variables yet.
Probably, these color changes are associated with this image format, and, say, Modify correlation will convert images to jp2 in this way.
It is interesting to check on other computers and other Map 3D.
Can you attach the raster itself or part of it?
todd_beavan
I got an answer from Autodesk support.  The problem with the resolution and color for the transformed image is an AutoCAD Map issue.  The TIF I was trying to insert is a Multispectral image and not a 4-band RGBA.  AutoCAD Map does not fully support the multispectral image.  So, the only way to move the image between coordinate system and not lose quality is by using a different software such as GlobalMapper or GeoViewer.
Just passing along information in case anyone views the thread.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
