If you cannot Query Civil 3D objects, how do you perform a coordinate conversion on them?
*The solution in my instance was to explode the surface model, retaining the contours and the surface model boundary.
Then I was able to perform a MAPWSPACE coordinate conversion via the QUERY function, then after converting to the correct coordinate system I simply re-created the surface model, using the contours and boundary.
