Query: count multiple objects (points) inside multiple area's (mpolygon)
MarkFissers1310
MarkFissers1310
Can someone help me with an example of a Query that counts multiple objects (points) inside multiple area's (mpolygons)?
Example: I've got multiple area's, and inside these area's are multiple points. I would like to see as a result the total number of points inside these area's... by area.
Thank you in advance,
Mark
Replies (15)
ChicagoLooper
Hello @MarkFissers1310
Please be more specific.
  1. What are your points? Shapefile? Gdb? Plain vanilla AutoCAD objects? AutoCAD entities with Object Data?Something else?  Both your object type and object format play critical roles when formulizing a solution.
  2. Are the polygon objects physically drawn in modelspace? Or are they 'imaginary' areas that can only be visualized by you? If Map3D cannot 'see' areas defined by your polygons then you won't be able to reach a resolution.
  3. Please thoroughly explain what you plan to do with the points once they're counted--there might be a more elegant way to achieve what you're after without counting the points in the first place.
Would you be willing to upload your points and your dwg file for a speedy and detailed workflow?
Chicagolooper
braudpat
Hello
You want to count objects like Points, Blocks/Symbols inside MPolygons !?
It's very difficult especially when you have complex MPolygons with multiples complex holes and sub-holes ...
Please a DWG ... Or 2 SHPs : one with Polygons / MPolygons and the other with Points ?
The Health, Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
MarkFissers1310
How can I share sdf or shp files ?
Looks like both files are blocked...
Kind regards,
Mark
ChicagoLooper
For SDF, click-and-drag the SDF. From the WINDOWS EXPLORER folder, left-click the SDF and drag it. Drop it here.
For shapefile: make sure all four parts are in a single folder. The 4 parts are (a) shp, (b) shx, (c) dbf and (d) prj. These are the minimum number of parts to a shapefile. You may have more parts (they'er extra) but the four mentioned are mandatory. You can click-drag-and-drop just like the SDF.
Before you click-drag-and-drop the zipped shapefile, you can create a compressed zip folder by RIGHT-CLICKING the folder then doing this: If you don't zip the folder, you'll need to click-drag-and-drop the ALL four parts as a GROUP or each part individually.
Chicagolooper
MarkFissers1310
Thank you for the explanation (is much appreciated)
Hereby are two zip files containing the shp files + shx, dbf, prj, ...
Grtz, Mark
parkr4st
your data to a map, analyse, intersection to the sdf file, data table from the sdf to .csv which can be sorted and reported as you please.  I chose access DB.
BTW no .prj files so your data is not georefernced as pointed out.
There are other ways that will get posted for sure.
TerryDotson
Good advice but unless I've overlooked something, these boundaries do not have any holes.  Can't the OP simply use the SELECT command, window (most cases) and use the "### Found" information echoed at the command prompt?
MarkFissers1310
Thanks for your reply.
Is it possible to get as a result something like the table below?
FeatIdNumberType_NType_JType_RType_L
1R05
2R03
3R02
4R01
5L04
6L03
7L02
MarkFissers1310
I had something dynamic in mind rather than a manual selection ;o)
TerryDotson
If you still need results from this dataset, take a look at the attached.
MarkFissers1310
Looks nice 👍
I have 2 questions:
1) what is the workflow (query in AutoCAD MAP) to get this result?
2) is it possible to expand the data-table of the polygon shape-file with those additional columns?
Grtz, Mark
parkr4st
one method to add the columns
First set a geographic coordinate system.   This should be done with all maps to georeference the data.
Next create a new SDF file with geometry set so  surface
and 4 new properties Type_N,J, R, & L
Put the sdf into the map and find create a new feature in the right click menu in Display Manager and draw a polygon around all the polygons in your map
Analyze, original polygons, new polygons as source and overlay respectfully, set a new file name for the output file and finish
The new polygons will have the columns in the table where the desired data can be filled in.
The original polygons file can be removed from the map as it is no longer needed
The data files in the .zip have all the data decribed above.  ME83-W is used as the GCS.  The GCS is needed to create a new sdf file, so set the GCS first in the local of you data.  Post for help if needed.
as for the excel file, export the data file to a .csv file and use excel, other spreadsheet or database software to work with the data.
TerryDotson
This is actually a new dedicated inquiry tool we're adding to our add-on software packages for AutoCAD and Civil3D.  We felt it was likely users may want to report on counts per data value such as your case and others like total single family homes by subdivision block, etc.
Not currently, we need to add column adding capabilities to our data write driver first.  Then we will add the ability to add these columns to the outer polygon data.
FJankovsky
I do a similar operation using QGIS.  It has many powerful algorithms for analysis that are not present in Map.
CADaSchtroumpf
1R05
2R03
3R02
4R01
5L04
6L03
7L02
@MarkFissers1310
With this?
(defun c:extract_data ( / ss n e v data_lst-mp p lst_pt ss_pt dn dj dr dl nb ep data_p data)
  (defun WriteExcel (data / xlApp wBook cells i j)
    (setq
      xlApp (vlax-create-object "Excel.Application")
      wBook (vlax-invoke-method (vlax-get-property xlapp 'WorkBooks) 'Add)
      cells (vlax-get-property xlApp 'Cells)
      i 0
    (foreach row data
      (setq i (1+ i) j 0)
      (foreach val row
        (setq
          j (1+ j)
          cell (vlax-variant-value (vlax-get-property cells 'Item i j))
        (vlax-put-property cell 'Value2 val)
    (vlax-invoke-method
      (vlax-get-property
        (vlax-get-property xlApp 'ActiveSheet)
        'Columns
      'AutoFit
    (vlax-put-Property xlApp 'Visible :vlax-true)
  (defun f (l i)
    (if (> i 0)
      (cons (mapcar (function +) (car l) v) (f (cdr l) (1- i)))
  (setq ss (ssget "_X" '((0 . "MPOLYGON") (8 . "polygons"))))
  (repeat (setq n (sslength ss))
    (setq
      e (entget (ssname ss (setq n (1- n))))
      v (cons 0 (mapcar (function -) (cdr (assoc 11 e)) (cdr (assoc 10 e))))
    (setq
      data_lst-mp
      (mapcar
        '(lambda (x) (ade_odgetfield (cdar e) "polygons" x 0))
        '("FeatId" "Number")
    (while (setq e (member (assoc 93 (cdr e)) (cdr e)))
      (setq p (f (cdr e) (cdar e)))
    (setq
      lst_pt (mapcar 'cdr p)
      ss_pt (ssget "_WP" lst_pt '((0 . "POINT") (8 . "points")))
      dn 0 dj 0 dr 0 dl 0
    (repeat (setq nb (sslength ss_pt))
      (setq
        ep (ssname ss_pt (setq nb (1- nb)))
        data_p (ade_odgetfield ep "points" "Type" 0)
      (cond
        ((eq data_p "N") (setq dn (1+ dn)))
        ((eq data_p "J") (setq dj (1+ dj)))
        ((eq data_p "R") (setq dr (1+ dr)))
        ((eq data_p "L") (setq dl (1+ dl)))
    (setq data (cons (append data_lst-mp (list dn dj dr dl)) data))
  (if data
    (WriteExcel (cons (list "FeatId" "Number" "Type_N" "Type_J" "Type_R" "Type_L") (reverse data)))
  (prin1)
