AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Publish to Web is Unknown Command in Map 3D 2019
1 REPLY 1
392 Views, 1 Reply
I have AutoCAD Map 2019 and I'm trying to use the command publishtoweb, but I get this error:
Unknown command "PUBLISHTOWEB". Press F1 for help.
I was reading from this page: https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
1 REPLY 1
Koesti
Hi @Anonymous,
I'm sorry that you have this issue.
This command has been available in AutoCAD (LT).
Unfortunately this command is available until AutoCAD 2018 and has been removed in current version.
Please find the details here.
The help files of Map are not updated to show this changes.
Thank you very much for reporting this and I will create change request to change the documentation to meet the correct behavior in AutoCAD Map 3D help.
Kind regards
Brigitte Koesterke
Technical Support Senior Specialist
