PROBLEMS WITH MULTI-LINE FEATURE LABEL USING EXPRESSIONS
dwattersAMXH5
dwattersAMXH5
I am trying to make a multi-line feature label using expressions. I have tried both of these expressions and yet the expression still will only show as one line.
Concat (  'FQNID#:  ', FQN_ID  , '\P' , 'LENGTH: ',  CALCULATED )
Concat (  'FQNID#:  ', FQN_ID  , '\P LENGTH: ',  CALCULATED )
where  FQN_ID and CALCULATED are being pulled in from my shapefile
i have also tried "\n" in place of "\P" and have no change in results.
my feature label is set as MTEXT, set to repeat along a poly line.
I wish to show
FQNID#: 123456
LENGTH: 1234
but what I keep getting is
FQNID#:123456 LENGTH:1234
AUTOCAD MAP3D 2018
Thanks for any help!
kajar
1.Use "Plain text" for multiline labels
2.Use '\n' for line break
3.Set  label position "Fixed location"
Kajar
dwattersAMXH5
So I cant use this with repeat position?
kajar
It seems this depends what data type is the source.
Workaround: try to use text as symbol instead using feature labels.
Then you can also set repeat interval for text symbols.
For SQLITE this text symbol trick works but seems not for SHP.
Kajar
dwattersAMXH5
ok, I'll look into that!
Thanks so much!
*EDIT*
This works for me with shapefiles and being able to set the interval is a huge bonus!
again, thanks!!
kajar
Glad this helped you.
Kajar
