Problem when connecting WFS
I'm having a problem viewing the data from wfs that I have connected using WFS.
The connection is successful but not able to add map (Add Map button disable). No error shown when try to connect to WFS.
Same thing happen when I try to connect using Autodesk Infrastructure Map Server 2015. The connection successful but not able to view anything. No error shown.
I'm using AutoCAD Map 3D 2016 & AutoCAD Map 3D 2017.
 Thanks in advance.
-Nik-
Koesti
Autodesk Support
Autodesk Support
Hi @Anonymous,
does it work with version WFS 1.0.0 instead.
Is it a public URL please share and I will perform some further tests.
One good test is to open with Gaia (free tool) and check if there is any message.
kind regards
Brigitte Koesterke
Technical Support Senior Specialist
Pointdump
Hi Brigitte,
I'd not heard of Gaia before. Nice! Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Pointdump
Nik,
I couldn't find that "landplandev" WFS address, even looking around their website. Is that a public WFS?
Dave
Dave Stoll
Las Vegas, Nevada
Thank you for the reply.
It does not work with version WFS 1.0.0 either.
Sorry, it is not a public URL.
I will try to open it with Gaia first and will share with you the result.
Thank you
-Nik-
Pointdump
Nik,
Have you tried yet to crack that WFS open with Gaia?
Dave
Dave Stoll
Las Vegas, Nevada
