Problem to Insert a Dynamic Blocks via script
nadiabelghithia88
Message 1 of 8
nadiabelghithia88
Hello to all,
I'm looking for a way to generate a script to insert a dynamic block.
Doing the insert command in a script is no problem, but the bock not take the correct coordinate X,Y.
So what is the worry!! lack of syntax in the line of script or graphic problem or .... !!   🤔  😔
For information, i'm using an AutocadMap 2017 (Frensh version)
I attache a .txt file contain all the lines of script in order to verify the command with me.
(Of cource, the .scr file will be lanced in autocad map)
Replies (7)
Message 2 of 8
cadffm
I guess your current setting of running osnaps and the current view while insertion is the issue.
You forget to handle the enabled osnaps.
Solution1
add the _none statement for "next point, don't use any osnap"
-inserer pointBloc _none
564354.4,283077.5,0.0 1 1 0
564383.5,283041.9,0.0 1 1 0
Solution2
Set up AutoCAD to ignore the running osnaps also in automations like a script, macro or (send)command
_osnapscoord 1
-inserer pointBloc
-inserer pointBloc
-inserer pointBloc
564434.5,283114.1,0.0 1 1 0
less smart idea solution3: Disable the running osnaps
worst solution3, remove all running osnap settings.
Sebastian
Message 3 of 8
pendean
Community Legend
Community Legend
Add this as the top line of your SCRIPT file
_OSMODE 0
Message 4 of 8
АлексЮстасу
Hi, @nadiabelghithia88
I replaced "-inserer" with "_-insert" (but this is probably not necessary). Replaced "pointBloc" with "pointBloc" - with a space at the end.
And put everything in dwg + Enter at the end.
1922 blocks were inserted.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 5 of 8
nadiabelghithia88
Thank you very much for the answers,
@CADffm
the Solution 1 gives good result 🙂
the Solution 2 --> autocad writes    _osnapscoord     unkown command
@pendean
_OSMODE 0  gives good results 🙂
thank you
Can You explain this syntax to me.
Message 6 of 8
pendean
Community Legend
Community Legend
@nadiabelghithia88 an underscore before the commandname allows the use of the core "English" spelling without being affected by a user's local language being different.
OSMODE is explained here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC... (it brutally removes all running object snaps, the problem you faced).
0 is the numeric zero (see link above for explanation).
The blank space in between is the same as hitting the <enter> key on your keyboard.
OSNAPCOORD is explained here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
HTH
Message 7 of 8
cadffm
Sorry for my typo osnapscoord vs osnapcoord..
Sebastian
Message 8 of 8
nadiabelghithia88
Hello @cadffm
Yes, I tried _osnapcoord 1 that given a good results also 🙂
