Poor performance on selecting connected shp file
Message 1 of 8
Autocad map 2011
I have very slow performance on selecting shape connected to a drawing. I takes a lot of time to select objects of the shape and panning is very slow too. No problem if I save all to dwg, it became very fast.
Tried in map 2015 and it works fine
Replies (7)
Message 2 of 8
It's the same with sdf files. Here an example.
Message 3 of 8
AdaZhu
Dear customer,
Thanks for reporting this issue. I have two questions about it. Could you help with it? Thanks a lot.
1. Is the Hardware Acceleration is on?
2. The attached data has a raster file connection. Does it impact the performance issue?
Regards
Ada
Message 4 of 8
1 on or off is the same
2 with or without is the same
I solved marked the shape linked unselectable.
Message 5 of 8
AdaZhu
Thank you for the feedback.
"No problem if I save all to dwg, it became very fast". Does it mean after click save button, the selection/pan became fast?
Did you reproduce issue in another machine?
Thanks.
Regards
Ada
Message 6 of 8
It means that if I convert to dwg ,removing link to shape, it's fast. The problem is the link.
It's the same on different pcs.
Message 7 of 8
AdaZhu
Dear customer,
Thanks for your help.
I tested with your attached data. But failed to reproduce it. The performance is OK. See the video  http://autode.sk/1QhHkVu . Any different step?
Regards
Ada
Message 8 of 8
I konw it works well even on 2015 version. The problem is on 2011.
