Can AutoCAD Map 3D be used determine SCS runoff curve number by overlay analysis of soils and land use maps?
Solved by bullera. Go to Solution.
The command is MapGisOverlay
it is available on the Analyze tab, Feature overlay button
Type drop down select an analysis type
to suit your needs
Save has a drop down for sdf or shp file
The resulting file will appear in display manager
I have not done that. Sound interesting.
can you post a link to the Arc-GIS instructions?
What data do you have that will be used in the calculations?
Dave
I agree, that does sound interesting. Out of the Box Map doesn't do this, but maybe check out the Catchment functionality in Civil 3D. That might get you closer to what you need?
If you don't have it, you can always get the 30 day free trial here.
Best of luck, and if you ever figure it out please come back and let us know.
Cheers.
