Online Map Scaling
cpogueGEFC9
Online Map Scaling
cpogueGEFC9
Hello all,
When importing new Bing imagery into CAD Map 3d 2025 the scale is in inches. For example when using Engineering Units it shows a city street is 5'4" wide when in reality it is 64' wide. I am using coordinate system AZ83-CF which is US Foot.
I have researched this for hours and am at a loss, any help is appreciated.
Thank you!
Replies (7)
ChicagoLooper
Hi @cpogueGEFC9
Your dimension is indicating 5ft-4inches which is 64-inches.
If you have assigned AZ83-CF then your modelspace has inherited (or adopted) units of feet, not inches. You should check your Dimension style and make sure you are using Decimal units, not architectural units. Arch units will use feet and inches while Decimal will use the units inherited from you Coordinate System, which is feet.
If you're using Arizona State Plane Coordinate System (SPCS) Central Zone, Feet, then turn on Bing Hybrid map. The imagery, if you have properly assigned AZ83-CF, will be consistent with your linework.
Bing Imagery
Geolocation Tab=>Online Map Panel=>Change from Map OFF to BING HYBRID
Chicagolooper
cpogueGEFC9
So both my Units and Dimension Style need to stay in Decimal when using Online Maps? I was trying to use engineering units so I could draft in feet and inches.
CodeDing
@cpogueGEFC9 ,
I think it helps to think of AutoCAD "Units" as Measurements (distances, angles, volume, etc.) and Labels ("in" "ft" "m" "cm"). What's happening here is this:
- YOU are telling your Model Space that a distance Measurement of 1 is Labeled as 1 inch.
- The Coordinate System interprets the Model Space distance Measurement of 1 as being Labeled as 1 survey foot.
So you and the Coordinate System have different Labels attached to 1 distance measurement. This is why @ChicagoLooper is saying that you have "inherited" feet. Because the Coordinate System does not know any better.
Best,
~DD
cpogueGEFC9
@CodeDing is it possible for me to change the label to show as feet? Or will it need to show as decimal?
ChicagoLooper
Hi @cpogueGEFC9
Your drawing environment which is your modelspace, has adopted (inherited) the units of feet. It has to. It must. It's suppose to. If it doesn't, then your coordinates won't be tied into the units of your drawing. Geospatial coordinates are always, without exception, one of the following:
  1. Feet
  2. Meters
  3. Degrees
Since you've assigned Arizona SPCS Feet, then your coordinates will reference (or tie into) the Arizona State Plane coordinate system's virtual grid, which in your case, has units of FEET. If you were to draw a point representing a fire hydrant, then your x,y coordinates might be
x=671,455.9356
y=885,890.4000
If you are drawing in INCHES then your equivalent geospatial position would be
x=8,057,471.23
y=810,630,684.8
If you do the math, the fire hydrant would need those INCH coordinates divided by a factor of 12 to convert from INCHES to FEET.
Since you're dealing with geospatial position, the units will need to divided by 12. If you, or Map3D, didn't do the conversion, then your fire hydrant will position itself using big, super big, COORDINATES that will put the hydrant in Colorado. Why? Because Map3D will use those inches and treat them as though they were feet.
If, however, the coordinate system used units of INCHES instead of FEET, then you wouldn't have to do anything, but since it's using FEET, you'll need to adjust your Dim Style accordingly.
You can adjust your Dim Style to reflect either Arch Inches or Engineering Feet (see image below, Phoenix Sky Harbor International Airport).
The red dims are using units of feet. The blue using architectural units of inches.
Same drawing, same measured distance, same assigned coordinate system.
Blue and Red dims are DIFFERENT dimension styles and despite the difference in style, the length is exactly the same.
The title of you post should really be How to make dimensions reflect architectural inches instead of FEET when I assign Arizona SPCS Feet.
Chicagolooper
ChicagoLooper
Hi @cpogueGEFC9
To set up your DIM STYLE you'll need to input the appropriate scale factor.
Continuing with the post above showing the DIMS at Phoenix Sky Harbor Airport, see the Dim Styles below.
Chicagolooper
cpogueGEFC9
@ChicagoLooper
Got it, thank you for the help, I really appreciate the in-depth explanations!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
