Need a lisp to create layout tabs automatically based on poly line in modelspace
vishwa0121
Message 1 of 9
vishwa0121
Can any body help me on this,
i need a lisp to create layout tabs automatically based on poly lines in the model space
those poly lines are rectangle which have equal dimensions.( see attached image).
poly lines does not contain any attributes
if layout tabs create at one instance is much useful
Please anybody help me as early as possible
Replies (8)
Message 2 of 9
braudpat
Hello
Q1) Is it always the same dimension for the rectangle ?
Q2) Which format for each Layout ?
A4 to A0 ? or ANSI-A to ANSI-E ?
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 9
vishwa0121
Hi
Thank you for your response
Below is the answers
1) Dimensions of the rectangle is same for all
2) it is set to A4.
Once I select all rectangle in model space automatically layout tab should
create as per rectangle.
Message 4 of 9
Yuvaraju.Dhananjay
Let me check this vishwa0121... Can you share the drawing and which HUB number and all.
Regards
Raj
Message 5 of 9
jtm2020hyo
share the lisp dcl please
Message 6 of 9
ChicagoLooper
Are you trying to reinvent the wheel? You don't need a lisp, Map 3D already has a procedure for that.
You may not realize it, but what you want is a MAP BOOK. Before you jump head first into a lisp (a lisp you don't really need) watch this >>VIDEO<<  by Jerry Bartels. It demonstrates how to create zoomed-in tiles for a wide area within your drawing. The individual tiles will be on separate layout tabs and the tabs themselves will be created automatically.
Chicagolooper
Message 7 of 9
jtm2020hyo
for some reason, I can not mark this as "accepted answers".
Message 8 of 9
saifumk8
Try Auto Layouts App from Autodesk App store:
This app will help you to create Autodesk® AutoCAD® sheet layouts by automation.
Just prepare the first layout the way you want it and provide inputs like sheet frame height and width, Sheet number, and Viewport.
https://apps.autodesk.com/ACAD_E/en/Detail/Index?id=8869324049075388295&appLang=en&os=Win32_64
Detailed Demo: https://youtu.be/a1bMaz5-nQQ
Message 9 of 9
maratovich
This topic is old. Your spam is ugly.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
