AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
missing list of layers with copytolayer
2 REPLIES 2
pascal.vieu
397 Views, 2 Replies
I'm using map3D 2008.
When I used to copy to a new layer through "copytolayer" I could select the new layer within a list of layers.
Now I don't have this list any more, I can only select an object in the new layer.
How can I get back a clickable list of layers ?
Thank you
2 REPLIES 2
Koesti
in reply to: pascal.vieu
Hi Pascal,
working with AutoCAD Map 3D 2008 - its a while ago, so I can not test anything.
What exactly happens if instead of showing the layer list?
Do we get any message in command line which help us.
In general if dialogs are not visible anymore some variables might be changed from 1 to 0.
To check this point please type the following variable to command line and press enter - change the value back to 1.
Filedia
Cmddia
Kind regards
Brigitte
Brigitte Koesterke
Technical Support Senior Specialist
pascal.vieu
in reply to: Koesti
Thank you Brigitte, it seems that the Cmddia was the good one.
Problem solved !
”Boost
