migrating custom settings
Good afternoon all,
 I have been patiently waiting for a response from Autodesk for a case that was opened on Tuesday (#11721965), three days ago regarding issues with migrating my custom settings from AutoCAD Map 3D 2016 to 2017 version. They helped me with the installation but didn't know how to migrate these files so opened a new case for me.
I've read the help suggestions but I'm not an IT person, just a drafter and can't figure this out. How / where can I find the "migrate custom settings utility"?
Spoiler
Spoiler
Frustrated AutoCad user
matthew.d
Hi @Anonymous,
Here is how to migrate settings within AutoCAD. I do recommend just setting them up manually though.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Alfred.NESWADBA
It's an AutoCAD option to migrate settings, but not for all vertical products (like Map 3D).
Can you describe why you need the migration tool and what part you like to migrate? In most cases it's the more secure way to just start with a new AutoCAD profile and do the customization again (load partial menu's, create a few pc3 files, configure the apps/tools loaded during start of AutoCAD Map 3D).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks Matthew!
I will give this a try...
Doug
Thanks Alfred!
I wondered since this has happened with every update to AutoCAD Map 3D...
Doug
UPDATE!
I did get a response to this case and successfuly installed 2017 AutoCAD Map 3D.
It's my custom menus that i want to transfer but I beleive I will need to do these manually...
Doug
Alfred.NESWADBA
If that are seperate partial menus then just load them in 2017 again using _MENULOAD (or _CUI) so you get them added to the existing predefined menus.
If you have modified the original menu files like ACAD.CUIX or so then start now creating your customization in new CUIX-files which are partially loaded, the big advantage is: you just need to load them in every new release, 2 clicks and they are there.
Never modify existing menu's because either you have to do that with every new version of AutoCAD or you use the old menu and so loose all benefits from the new release menu.
- alfred -
Alfred NESWADBA
