AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
maps 2023 refsys not printable
9 REPLIES 9
Message 1 of 10
Bwanamiti
370 Views, 9 Replies
Hello all together,
I just installed ACA maps 2023. Unfortunately lines within view frame of maps reference system (UTM-grid) are seen in print pre-view but not printed (ACA-pdf-printer). All layer parameters checked. Background is PDF-imported map. Didn't have problems in previous version.
Thanks fpor answers
regards .hb.
post@hbosse.de
9 REPLIES 9
Message 2 of 10
ChicagoLooper
in reply to: Bwanamiti
Hello @Bwanamiti
When you refer to maps reference system do you mean MAPLAYOUTREFERENCESYSTEM?
Although your opening post may be clear to you, it's not clear to the forum.
Are you trying to print the UTM reference grid of the viewport to PDF from your layout tab?
Please upload at least 3 different screenshots illustrating your issue. For example:
  1. A screenshot of print preview.
  2. A screenshot of the PDF which demonstrates the error.
  3. A screenshot of the Properties Palette when the reference grid has been selected.
  4. Any additonal screenshots you believe are relevant to your issue.
Chicagolooper
Message 3 of 10
Bwanamiti
in reply to: ChicagoLooper
Screen Shot 04-27-22 at 06.31 PM.PNGprint preview
Screen Shot 04-27-22 at 06.32 PM.PNGprintout
Screen Shot 04-27-22 at 06.38 PM.PNGlayer parameters
Screen Shot 04-27-22 at 06.34 PM.PNGproperties
Hi, Chicago Looper,
thanks for your quick answer
Yes I meant MAPLAYOUTREFERENCESYSTEM
in drawing and print preview the coordinate grid is visible
print out with ACAD pdf printer high quality, related layer enabled for printing
in PDF coordinate grid is missing.
I attached fotos above
Regards Bwana Miti
Message 4 of 10
ChicagoLooper
What are your plot settings?
Can you try it like this?
Using MGRS format with Scale 1:2000 and Precision=100m.
Chicagolooper
Message 5 of 10
Bwanamiti
Thanks for your answer.
Here my page/print settings, seem to be very similar to yours
And my coordinate system settings:
Bwanamiti_1-1651574611533.pngBwanamiti_2-1651575759628.pngprint preview
Incredible, the lines are back, reasons for it are not understandable. I tried to reset: SYSVARMONITOR (Command)
Which are the sys.vars for the PLGRIDSYSTEM?
Best regards .hb.
Message 6 of 10
Bwanamiti
I can't believe. The problem is back. I made no changes to the parameters.
print preview:
print out
I kindly ask Autodesk Specialists for a solution
regards .hb.
Message 7 of 10
pendean
regards .hb.
You can do that yourself anytime you want:  start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
Message 8 of 10
Bwanamiti
in reply to: pendean
Thanks I will do
Message 9 of 10
ChicagoLooper
Your explanation summarizing your issue is too vague. There are too many variables that your situation. Upload your drawing.
Chicagolooper
Message 10 of 10
Bwanamiti
Dear ChicagoLooper,
I appreciate your support.
Attached you receive the DWG as eTransmit (I detached the XREF because of size).
Plus 4 PDF printouts just made one after the other within short time.
NB: The first printout showed again the grid, strangely enough, but subsequent prints are not showing the grid anymore, see file dates.
I draw some lines myself to get at least something looking like a grid. Layer: 91_PSP_RefSys_LIN
Layer 91_PSP_RefSys contains the grid. Pls toggle layers in PDF
Thanks and regards
.hb.
”Boost
