Message 1 of 11
I use the MapImport command to import Shapefiles into AutoCAD Map 3D. For the points I have mapped the data entries to Attributes within the block so they display within my drawings.
The Attributes populate successfully however anything that is a number from the Shapefile populates with 15 decimal places. This doesn’t change or appear to be controlled by the unit/precision settings of the drawings.
Is there a way to set the numbers to one decimal place when importing the shapefile?
